Download a pressure/temperature chart. But there should also be a temp scale on your high side gauge.
If the pressure is 175, then the saturation temperature (the majority of the condenser) should be 121 F. 10 degrees of subcool and the liquid leaving the cond should be 111F. So get the system running with the cab a reasonable temperature on recirc full fan, get the fan clutch on, RPM at 1100 or so and add charge slowly until your subcool is about 10F. This is the gold standard for charging if the calibrated weight is not available, or if they got it wrong.
It would be nice if they had sold you a 134A ex valve. Usually that's what you get these days.
As for freezing, there should be a temp probe hooked to a switch to disengage the compressor temporarily as the evap gets below freezing. Usually this only happens on lower fan speeds.
It sounds like you need to add charge but I always do it by the subcool method, it is directly measuring what you need to be measuring, but it needs a thermocouple, no point and shoot thermometer for me on this one.
Ok so I been setting here all afternoon thinking about this and what you said. Here are my performance numbers.
condenser inlet 105° @ 200psi high side
condenser outlet 85°
evaporator outlet 41° @ 20psi low side
86 ambient temperature
Ok so if I go by what your saying i have a temperature drop across my condensor coils of 20°. I think what your saying is I want to achieve a droo of 10° which would be prime sub cooling?
So given that my high and low side gauges are low and my sub cooling is 20° The only conclusion I can draw no matter how many times i beat it is that im low on freon charge.
I already have 3 lbs in the system which seems max to me. I just cannot get over that it would take more. I remember what you said aboit some trucks with sleepers taking 4 lbs or more. This truck had a sleeper on it originally. It has been converted to a daycab. The sleeper did not have a stand alone evaporator coil separate from the cab evaporator. It had two fans on the cab mounted evaporator under the dash. One fan was ducted to the sleeper. All the ducting is still there but just dead ends at the back wall!
Ok with all that being said the evaporator is quite large. Its about 21 inches long and about 8 to 9 inches wide and two inches thick. When I think about it it is much larger than the fld which has a sleeper mounted evaporator unit.
i guess im just gona have to get it in my head how large this system is and that it is gona take more than 3 lbs which is spec for a daycab fld. Unfortunately i just cannot find any information on the old flc system from freightliner or any old knowledge from anyone experienced on that exact model truck.
What's your thoughts on where i need to go on this?
