Cat 259d Door sensor issue Fault Code 2471 - 4
briarpatch
Abbotsford
Hi to all
I was searching for an answer to a couple of issues and came across this forum which helped with other problems but not this one.
I recently purchased a 2015 Cat 259d with 1150 hours. It had a busted windshield which I replaced, all the parts were there. After the door install the machine runs great except the windshield washer/wiper does not function and the arms could raise with the door open which obviously is not good. Earlier today I got out the manual and located the jumper, this corrected the windshield washer issue but the wiper still did not operate and the lift arms were now locked out. I unplugged the cables put the jumper back in and it worked as before. When I removed the jumper and reconnected no arms and still no wiper, not sure if the wiper is a connected issue or separate.
A fault code came up and went off before I could review it, so I repeated the process again. This time the fault code remained it is "2471 -4 Cab Door Position Switch Voltage Below Normal"
I cleaned the sensors and adjusted them no change. I had read that this could be bypassed with magnetic tape so I tried, when I closed the door I got a message "Cab Door Position Switch Voltage Above Normal"
When I purchased the machine the door parts were in a box and the wiper assembly was in the cab, it was an owner operator who rarely used the machine due to a change in his business practises so it had been like that for a couple of years, the machine had just been serviced and was mainly kept inside.
Any Ideas
Thanks
First up, please post a Serial Number. You are going to need the electrical schematic sooner rather than later by the sounds of it and it's important to get the correct one corresponding to the machine S/N.
A quick look didn't throw up anything regarding 2471-4. Are you sure it wasn't 2471-3.?
EDIT: Found 2471-4, just need a Serial Number to makesure it's appropriate.
briarpatch
Abbotsford
Nige we got the 2471 -4 Voltage below normal and when I added a magnet strip 2471 - 3 above normal.
Do you want me to PM you with the serial #
briarpatch
Abbotsford
Nige we got the 2471 -4 Voltage below normal and when I added a magnet strip 2471 -3 Voltage above normal
CAT0259DTFTK00829
The door switch is a two-pole device with a 3rd (common) terminal connected to machine frame ground.
The ECM has two inputs for the door switch. Conn J1 Pin 54, & Conn J2 Pin 52. It has to simultaneously see ground on one terminal and open circuit on the other. Otherwise it will generate a 2471-3 or -4 Diagnostic Code.
Here's the troubleshooting for the -4. I'll PM you the electrical schematic
  • CID2471 FMI04.pdf
briarpatch
Abbotsford
Thanks for your help tested and the switch turned out to be bad. Replaced and all good.
Only thing I have to fix now is the wiper. The washer works but no wiper, fuse is good so probably something in the motor.
Nick
briarpatch
Abbotsford
I have took the motor off and unseized it so just have to put it back together and test out. I thought it would have blown the fuse as it was seized solid, hopefully it works now
briarpatch
Abbotsford
1st have to admit I am better at mechanical than electrical.
I have taken the readings at the connector where I would hook up the motor
I have tested all the fuses and all good using a power probe 3.
Black is a good ground.
When ignition is off 0.0 reading. brown no reading
Ignition on 12.1v at grey & green, brown has no reading.
Not sure what this means, but I am thinking that I should have got a reading on the brown?
With key ON and the wiper switch in the ON (1st) position at the connection for the wiper motor you should have 12v: -
1. Between wires 118 Grey & 200 Black.
2. Between wires 501 Green & 200 Black.
The 500 Brown wire will only be briefly live while the motor is moving to the "Park" position after the wiper switch has been moved to the OFF position.
When you move the wiper switch to the second position does the washer pump work.?
briarpatch
Abbotsford
1. 12v
2.12v
I will recheck the brown wire but that makes sense because I thought I had a reading at 1 point
Yes the washer pump is working
I also tried to put power to the motor unit and could not get a response from it
Thanks
Nick
briarpatch
Abbotsford
To test the motor I tried in the machine and also on the bench. I attached the ground connection to the black and tested the ground and it was good. I then applied 12v to each of the pins and got nothing. I then attached ground to the motor body and tried again still nothing. The motor and wiper arm connectors are spinning freely by hand.
The only thing that I did notice there was a thin steel (I think) spring type wire at the top of the armature that did not appear to connect to anywhere, I have never noticed this before on other motors.
Thanks
Nick
briarpatch
Abbotsford
I attached the ground of the power probe to the ground and power to 3 & 4, the motor did nothing no noise no movement. I am thinking that the motor is burnt out?
