JLG 40F manual
Puggles
Kansas
Well so far this wiring schematic is newer than what my unit looks like my unit only has 1 cube relay it doesn't have all the relays this print shows any suggestions on what to do besides junking it
OFF
Alberta, Canada
HD Mechanic
Here's some more specific 40F diagrams for Racine valves. Not as general as what's in the manual. There were older JLG versions of the 40F, but I don't think they were called 40F. This one shows two relays in the main control box.
  • JLG 40F Racine basket.PDF
  • JLG 40F Racine ground.PDF
  • JLG 40F Racine main.PDF
OFF
Alberta, Canada
HD Mechanic
40F's with Bertea proportional valves only had one relay in the main control box.
  • JLG 40F Bertea basket.PDF
  • JLG 40F Bertea ground.PDF
  • JLG 40F Bertea main.PDF
OFF
Alberta, Canada
HD Mechanic
This is what a bertea proportional valve section looks like.
JLG 40F Bertea valve
  • a" style="margin: 0px; padding: 10px 10px 0px; overflow: hidden; zoom: 1; background-color: rgb(245, 245, 245); border-radius: 5px;">
    File size:
    53.4 KB
    2,626
Puggles
Kansas
Okay I will check them out thank you
Puggles
Kansas
    File size:
    53.4 KB
    2,626
That is what my valves look like
Puggles
Kansas
These prints look like exactly what I needed and I appreciate and thank you very much I believe I will be able to get it going now thank you for all your help and support
Captain Mitch
Welcome
Yes, I do. Just send me a private message with your email address on it.
hey this is Captain Mitch here. Just joined heavyequipementforums and I hope that someone can help me with jlg 40F manuals. not even sure how to do this
OFF
Alberta, Canada
HD Mechanic
I got you Captain Mitch. You might want to edit your email address out of your post. Just in case.
Puggles
Kansas
Captain Mitch did you get what you needed. I have gotten everything to work just fine on my 40f jlg boom lift.
Captain Mitch
To the person that E-mailed me files on two E-mails seven attachments total Could you please resend them I tried moving them to save them and I lost them Thanks Captain Mitch
Puggles
Kansas
Here's for the bertea
