sandnsnow
Looks like the Cat is hard to see out of. Ill stick with my TL150. Good looking machine. I agree with CM1995, These machines are so fast at moving material it is had to go back to a small dozer.
How's going..... So you didn't like the T190 either....
I have never understood how anyone could demo one and still buy it.
Not too bad, with the current market and all. I see you and Hoeman are up to more "after hours" shenanigans with the Coal Tour.
I was told that CAT would continue building their "goofy" MTL until at least 2012. I have also been told that if you add up both CAT and ASV machines at least 50% of all track machines sold habe that "goofy" track system.
You are way off with your 50% stat, I beleive it is closer to 25% combined and getting lower every year with that plastic/rubber set up
Good to see you again, L -- didn't see the video you took? Could be my own issue.
Tigerotor, scroll down a bit. It's in the middle of the story.
-Rod
The information I have was pretty solid and is based off of total machines manufactured since the introduction of the CAT MTL starting with the 277.
If you look hard enough there are two forums/websites that feature equipment discussions that you haven't visited yet in order to bash CAT. You must have a heck of an axe to grind. I'm not trying to hack on you but every post but one that I've read of yours hasn't been constructive but merely significantly negative.
I have been told that CTL industry data will be reported next year just like skids. So there won't be anymore guessing games about marketshares.
WOW!!!! I feel like I am being stalked!
I am not bashing Caterpiller just bring up points that don't get spoken about. Some people get blinded by the brand.
I am being constructive but sometimes it will be negitive. The truth must be spoken!!! All brands have problems and this is a forum to speak about the good and the bad. To try to teach and learn something while we are here.
I will let you know after Thursday, Cat is supposed to drop off a 299c have had a Tak tl250 for several days and was amazed at the power and the productivity of the machine, I am 6' 1" 220lbs and I felt small in the cab.. Have had a few hours on a Cat 289c that could not even come close to this machine but did have a better ride, although am not sure if I like the suspension in the undercarriage for lifting and grading..
