fencefool
I don't know if this has been discussed but what are the major performance differences between a vertical and radial lift. I have a TR 340 in the shop now for a DEF sensor. It's a machine that isn't worked hard mainly running at idle running a post pounder. I'm looking at the TV 370B because it is the comparable size but with the vertical lift and 75hp so no DEF. My machine sits most winter unless there is no rain. As far a pushing dirt and an all around attachment machine, are there weak points in all the components that make it vertical lift. The radial seems real simple on how they operate. My machine has 230 hours in 2.5 years so I can see the DEF starting to be problem. Offer on the table for 36k now but feel it's worth more. All the bells and whistles except for enhanced high flow and it's mechanical hand controls.
