Tony Wells
Greetings all!
Had an issue pop up today on an excavator. The machine is
Volvo
Model EC250EL
Serial VCEC250EK00310165
Symptom as described to me: This box ↑↑↑↑↑ (main power relay I expect) Seems to fail to latch when the small control toggle switch is turn on. Naturally, the machine will not start while it is bouncing, but after sometimes 6 tries, sometimes more, it will latch and everything works. The machine starts and everything in the electrical system seems to operate as it should. However, arbitrarily, this relay, if that's what it is, will break during operation and the machine will die and the operator has to climb down and work the control toggle a few times to get it to stay latched. Customer's service guys have replaced two relays in the fuse panel to the left of the view from taking the picture.
Before I rip into it, I'd like to know a)what it is and b)how is it controlled, by the small toggle switch by the door and through the relays, or directly, or just how. The owner wants to just pull it and open it up, but he doesn't understand what controls what or how.
Is the wiring entering the enclosure the trigger wire or an output signal carrier? I really need a piece of a schematic. But if someone can explain exactly what is supposed to happen when the control toggle is switched on it would help. I just don't care for diving into something I don't understand pretty well. Ops Dir wants to just replace it. I'd rather not bury it in dollars, but since I don't know the system....
Suggestions?
Volvo
Model EC250EL
Suggestions?
