Doug580l
I replaced the bushings and pin at the end of the dipper arm last winter. I noticed that the bushings that the pin that holds the bucket on goes into were kind of loose so I tried to shim them. Didn't work. One of the bushings slid inward and blocked the area were the grease comes in. Is there a way to secure the bushings so that they don't move? Maybe some kind of adhesive? I also thought about grinding a few little grooves into the end of the bushings and frame then welding them in place. Any ideas?
Thanks,
Doug
Thanks,
Doug
