Just have to finger out what the CRAP is happening, a grunt mechanic will find a way to work around it.
Get to work this morning Same SDD, have clay to haul up 18 miles then go to different pit and haul back for barge loading(Different clays). Check Fluids I can, tires, brake adjustments and leaks, all good. Made first run out, loaded, then up and dumped, second was similar UNTIL was reloaded and headed to river.
Out of NOWHERE Engine Alarms, Three lamps on dash, beeping and whistles going off, Engine IMMEDIATE Shut down notice. First action glanced to ALL the main engine gauges, temps fine, oil pressure fine, then the damn auto shut off cuts in W.T.F., Mo HWY 19 around six miles south of anything, driveways ONLY so step on clutch to veer into/across one, BAD Choice, engine dead no p/s, back to good ol Armstrong and off the hwy. Get out recheck obvious fluids Oil Antifreeze STILL OK. Cycle ignition and restart, still in alarm but parameters still good, NO Noises from engine, no squeals no bumps no grinding or banging and a FULL load of clay aboard. So the beast dies again, I let it sit a moment and hit it again, down the road we go. Get to the grade to big Springs MO, at least all down grade, limp it thru there and dies again, with engine rolling coasting cycle the damn key back to running reset alarm, managed this to get the machine to the river lot and offloaded the clay, head thru town doing same and made it into shop lot. None times died and restarted. Set the boys on it and take the spare, get last two loads of day and come back all fixed. 'GD' DOC Temp Sensor failed, JUST Happened they had one in a box on the shelf as a test device from a previous failed DPF DEF SCR system. FKNG Emissions garbage.
Tomorrow back in the better truck.
