treemuncher
All of my purpose built forestry mulching machines have come with precleaners installed from the factory. I also had a precleaner on my old skid steer. I'm looking for others' experiences to compare with mine as to which models to purchase and what to avoid.
Sucked to be me about a month ago while I was mulching and noticed some black plastic run through the cutterhead on a back cut. I did not realize it at the time but it was the remnants of my Turbo III precleaner that came with the machine. It had fallen off after limb strikes a few times but I had always been lucky enough to catch its loss before I killed it. My luck ran out that fateful day..
I could not stomach nearly $500 for an identical replacement so I started comparing what was available on Ebay. I did not have anything the correct size in stock in my shop, only smaller units. I used to have an Enginaire Precleaner on my Posi-Trac and their lifetime replacement warranty was awesome. Great service from those people. So after comparison shopping on what was available and for pricing, I purchased another Enginaire sized for my 8.3 Cummins at less than $200 for a new unit. After the first week of operations, I was really disappointed with the precleaner's performance. Normally, I could go for 2-3 weeks in dusty conditions with the Turbo III before the air filter was dirty enough to mess with. This time, after only 2 dusty days, my restriction guage was halfway to the red so I pulled the air filter and cleaned it. It was the dirtiest and fullest air cleaner to ever come off of that machine. The Enginaire precleaner was hands down a miserable loser in comparison to the Turbo III. This happened twice to get to the "need to clean" stage in under a week in less than miserably dusty conditions. I got back online and spent the cash for a new Turbo III and installed a leash on the thing so I won't ever lose it completely again. I should have / could have put a leash on it after the first escape attempt and saved some coin.
I'm looking for input from others with their experiences on different precleaners and what works best. I've found that a good precleaner saves me a ton of time and I worry less about my air filter maintenance. I'm considering changing out the unit on the Barko with the Cummins 9.0 now. That one would sometimes choke the filter to alarm status as much as twice a day in really dry conditions - that Turbo III might stop that from happening so often being that the factory unit looks the same as the Enginaire. But maybe there is still something even better out there?
