Martin Fleming
I've got an old 16 ft stake side flat bed truck with a scissor hoist that ineed to re do. Its a 1971 Ford C600 22k gvwr.
The wood bed is completely rotted out. At one point there was a steel bed on top of it because I can see where they ground thru the stitch welds along the frame edges.
Im got some 2x6 cedar that ill lay in and then 4 sheets of 3/16th steel diamond plate. My question is, if i weld the four sheets together to make a 8x19 floor can i get away with stitch welding the edges along the frame rails? Or do i need to also bolt thru in tne middle here and there?
Seems like the weight of the steel will keep it from lifting up off the wood subfloor but i thought id get some other opinions. I use the truck to haul materials and occasionally up to 5 yards of gravel.
Thanks.
Thanks.
