maineplower
I’m trying to diagnose a problem with my travel speed not changing and being jerky when the rpm’s are up. I have the palm version of drzx and I keep getting connection problem. Any advice? Thanks
code 26
There is also a slight hydraulic noise like a relief valve when operating the machine, the hydraulic oil also gets very hot after a while
PM tool king he will help you out with thatWhere do I get mpdr? The dealer?
This is the interface tool number from hitachi /deere 4476512 that will have the four pin plug on it.
JD can get you one in a few days. If your close to Corinth you could use
