Help inform a study
California
A practice that gradually is changing is the starting of a diesel engine once a day, or in cold climates, less often than that.
Diesels use little fuel idling. Popular belief has been that starting a cold engine is far more destructive than idling long periods. I have close friends with a dozer. It sees little actual use, sort of a trailer queen. Its use is nearly limited to finish grading. It gets started if they think they might need it. Numerous times it has been started, thinking they needed it, but plans changed, a day or two later they come upon it still idling. I once read the clock at 27000 hours, that was a few years ago.
Electric machines wouldn't idle. Use hours will run near 1 KW per HP factoring inefficiency.
That's helpful, thank you.
California
From what I've read, the cold is much worse for batteries than warm is. Up to a 40% decrease in battery life in cold temps. Lucky in battery testing range for cars, they don't test in Minnesota or the North Slope.
There's lots of issues with electric for construction equip, vs in a commuter car. For the dirt working guys, there's usually no outlet on the site when they show up. Nobody is loading the equipment up every night and hauling it back to a power pole, moving equipment from site to site costs $$$. In a commuter car, you start it up, drive your 20-30 minutes to work, then back home again. AzIron is going to beat a electric backhoe with a hammer for 10 hours straight. A farmer in North Dakota is going to go out to a tiling job, and he wont see a power pole within 10 miles of him, let alone a outlet.
Electric is gaining a foothold in London, where they have strict emissions requirements, and the built up infrastructure. That's where electric is going to have to start, in the LA, Chicago, New york City and industrial/factory work.
Also, I'm your market guy for a electric. I run cranes, and the new dpf systems like to be run hard, and on the jobsite we don't run very hard. Lots of idling time, and the new engines aren't taking it very well. But I don't want all electric, I'm trying to move 100,000lbs machines down the road. I want a big 400hp 1800ft.lbs torque diesel motor in the carrier to drive down the road, and a 4 cyl, diesel electric hybrid upstairs to run the crane, like a Prius. Battery gets low, the engine comes on to charge it. I'm sitting there holding a piece for 3 hours, and I get to run on battery power. Working hard and my genset diesel kicks in. I would even settle for running the big engine to charge the battery if I had to. New 100 ton plus cranes are expensive to start with, so there's more $$ margin to work with to add the cost of a electric system. Whereas the skid loader market is much smaller $$$, and very competitive on price.
As far as fuel usage, I'll burn around 20-30 gal in a typical day with my 300hp smaller cranes, my bigger cranes can burn up to 50-60+ gallons.
I'm probably the closest one here on idling 50% of the time. For most equipment, time is money, jobs are bid, and the equipment has to be moving to be making $$$. Idling is really hard on the new emissions systems, so the manufacturers are all about shutting off equipment that isn't working. So very little equipment is going to have that much idle time.
I see electric taking hold first in the crane, manlift, and telehandler world. Then working its way to the dirt equipment and long haul trucking. But I think hybrid ICE with battery, makes much more sense, and would be much more readily accepted than straight electric.
That's really helpful, thank you.
California
As shown by all the comments above, one can't make any kind of basic assumptions on machine use that covers all diesel powered machines. Parameters have to be set. Type of machine and its typical use, size of power plant, type of material being worked, job schedules, operator expertise, maintenance practices, management styles, projected age/use of the equipment and on and on. Electric fork lifts work good in a warehouse but not so much on an open construction site. Finding and loading up enough batteries to replace the engine in a Cat D11 is going to be a very heavy task let alone providing a charging station for.
You are also also looking at reinventing the wheel. Komatsu is already putting together a battery powered excavator. There is a lot of work being done on battery powered wheel and track loaders. Case has a battery powered backhoe out on field trials right now. This web site is a great source of current operational knowledge. However, you might try looking at the trade magazines and places that provide industry marketing materials. They are long on hyperbole but sometimes there is some actual truth that comes out.
Thank you, I didn't know about the Case and Komatsu trials. The Case website is very helpful. Thanks for your feedback.
AzIron
Az
You need a machine that can run at 85 percent of capacity for 10hours aday to be able to market it anything less and it will fall short of demands and a few bad experiences will taint the program for years
I myself wouldn't even look at a machine for battery unless it came to that criteria
63 caveman
western Pa.
Great point about running the A/C.
Regarding how many hours per day: I am trying to figure out what is reasonable. If machines are running constantly or in remote locations, battery is not a good option. But I have no idea if it's common for a machine to run 2 hours per day, 5 hours per day, 10 hours per day? The key here being: what portion of users want a piece of equipment that needs to charge after running X hours? That's what I am trying to get an idea of. I'd hate to use an estimate that only serves 5% of people, but 50% might be acceptable.
Awkward Potato,
Not looking to offend you but.... You seem to want input from folk that are in the trenches that will prove your point. No one wants to disprove your attempt to come up with a better source of power; Most of us guys in the trenches HATE to see waste. Most of us are thankful for the natural beauty and resources we have enjoyed and want them to be managed so future generations can share that same experience and support anybody that can come up with REAL solutions for other more sustainable energy sources. But we have also seen crap like ethanol jammed up our hind parts (engines designed to run on 10% do ok, engines not designed for it just pass it though, and "flex fuel" engines that are required in many states are not able to run efficiently on ether gas, 10%, or 85%) and diesel "after treatment" systems that have been a enormous increase in operation cost (including additional fuel) with very questionable positive results. So please don't be personally be offended if some of us are not wanting to get battery powered HEAVY EQUIPTMENT.
On the bright side I no longer fire up the big compressor to knock of a few bolts, instead I grab my battery powered inpact!
Keep the faith brother, I hope you come up with something REAL for all of our sakes.
Jonas302
mn
Thanks Potato for trying to get some input from real users like you suspected %50 usage is low and can vary so much from day to day
All equipment built in say the last 20 years have computers that track idle time ect and with all the telemetrics all the manufactures know what the real world usage is
Coaldust
North of the 60
63 Caveman brought up some good points. This subject of battery operated equipment has been studied to death. I remember being a struggling University undergrad in 1990 addressing the same questions Awkward Potato is asking 30 years later. The market did what markets do.
The market provided us wonderful battery operated aerial lifts, lift trucks, underground mining equipment, and whatever else that makes economic sense
Admittedly, I’ve never done original research. When I finished my graduate work, I opted for a M.Ed. I took an 8 hour comprehensive exam instead of doing a research paper. That doesn’t mean I don’t understand the process of original research.
awkward hasn’t demonstrated any sort of research Protocol. The OP hasn’t introduced themselves or their pronouns, the institution, the study, and all the other disclosures and permissions required to gather research data. I don’t understand what the angle is.
Flame me if you want, I spent half my career in Higher Ed. I understand how the academic research biz works.
California
Awkward Potato,
Hi Caveman,
No offense taken. I don't have a dog in the fight (not being paid to work on the project), I'm just trying to make the project better by getting input from real users. Electric equipment has some great advantages, but a lightweight and long-lasting fuel source is not one of them. My goal here is to make sure the results of the study reflect reality, so that the readers/decision makers are informed and recognize where batteries are viable and where they are not. If the reality is that battery can only replace diesel in a few special situations, the report should say that rather than claim most equipment can be converted to battery.
California
Thanks Coaldust,
To clarify, I am not part of the research team, am not representing an institution, and am not gathering data for research purposes. I was asked to provide feedback on a study, and it seemed important to run assumptions by real-world users to help make sure the research reflects reality. You are correct that if I were part of the research team I would go through official routes and pay folks for their feedback. I am grateful to everyone here who has contributed.
When speaking of HE while looking at say a D8 high track
Weight in excess of 35 ton
Need to be able to move the base mass then the product being cut away
HP is HIGH to move all that need be moved so energy use as in hp vs work performed will also have to be High requires a load of battery energy regardless gear reduction.
