You set them?set them to around 2500psi
Yes they are adjustable for pressure, not sure if 2500psi is correct, could be letting to much fuel into the motorYou set them?
Thanks this will help with the trouble shootingfrom the 188d service manual
It looks like it's working ok, but I will recheck it,Check the fuel shut-off lever on the injection pump.
It is possible the end of the cable is broken or came off.
Or the lever may not be turning the shaft.
Just from the outside, I pulled the injectors out of the head, and hooked them up to the injector pump and cranked it over so fuel is spraying out of the injectors. I took a video but not sure how to post itDid you open the top of the injection pump to check it or just from the outside?
