John deere 790D slewing issue
davecampbell
Oklahoma
20210401_100223.jpg Would kind of grind to a halt when swinging. It was not consistent on where it stopped. I swung it until it hung up and left bucket up a little off of the ground with a safety chain. I could swing it a small amount by hand so swing bearing seemed fine. When I pulled the swing motor the planetary housing came with it but it immediate swung to the limits of safety chain. I figured it was the swing brake at that point. Pulled that apart and it all looked good. When I inspected the planetary gears I found one of the sun gears on the lower planetary had ate up bearing. And ruined pin. Gear was not available through deer so I ordered the pin and thrust plates. I took the gear to machine shop and had them press out the bad bushing and make a new one for it. Reassembled and symptoms are still the same. Is there a way for me to check and see if its loosing pressure to swing brake? Could it be something locking up in the swing motor itself?
lantraxco
Elsewhen
Typically what stopped the swing on these AIR (As I Recall, subject to CRS, Can't Remember Stuff) is actually the hydraulic motor and the counterbalance valve, then the brake comes on after a short delay, there should be a restriction in the hydraulic feed coming out of the brake someplace, maybe that block bolted on the side of the case near the brake. See the two relief valves cartridges in the motor head with the rubber caps on them? I think they're part of the counterbalance system. Motor could be coming apart also, piston setup...
uffex
Lincoln UK
Admin
Good day
You may find the attached helpful.
Kind regards
Uffex
  • Swing transmission1 r .pdf
  • Swing BrakeFunction 1.pdf
davecampbell
Oklahoma
So I had this theory that debris from the sun gear bearing failure had contaminated the bottom bearing so I pulled it all back apart. But I can't get the pinion gear shaft out. I did get a snap ring off of inside but its not budging. 20210404_145227.jpg
mg2361
Pennsylvania
Equipment Mechanic
That's because you need a 100 ton press. Even then it might not come out. I have even had the housings break trying to press those buggers apart. So now I don't even put them into a press until after I have sliced the top bearing inner race with a torch.
davecampbell
Oklahoma
Ill try cleaning that valve before i reassemble, yes, we ended up slicing the bearing race to get it to break free.
davecampbell
Oklahoma
So my theory was incorrect. New lower bearing and seal. Cleaned and inspected everything else in planetary. I'm thinking it time to clean valves or check pressures. Twice I've locked it up and had it swing free when slewing motor was unbolted so I'm still discounting the swing bearing being my issue. 20210416_131540.jpg
davecampbell
Oklahoma
Take the brake plates out of the motor to test it.
the first time I pulled it apart I pulled the brake apart and everything looked great. Are you saying to reassemble it without the plate so that I can know that it is the brake malfunctioning?
lantraxco
Elsewhen
If Reassembling with out the brake plates stops it from sticking then it's either a problem with the brake or the brake solenoid
And if not, then motor? Is the control spool an open motor spool? I didn't see a counterbalance spool in the parts breakdown?
Dave Neubert
Monroe NC
Are you sure that the turn table bearing is good have you checked it for play they can bind up if they are going bad might not happen when you swing it manually a little
davecampbell
Oklahoma
twice i have taken the swing motor off while it was bound up and bucket in air. Both times it freed up and swung into my safety. I can try swinging it farther manually to see if it binds up. Also, when its bound up I can push on bucket wit my hand and feel the slack in swing drive. I put a pressure guage into the top of 20210417_104228.jpg the little valve bolted to side of swing motor. Seems to be pilot pressure. 500 static and 800 when trying to swing but locked up. It hits the same 800 if I bottom out crowd cylinder. My cell is 619 889 1589
