Case 488p need help
davecampbell
Oklahoma
I had a komatsu pc200-5 that did that. Ended up finding a screen on that pilot control valve intake. There was trash that would plug the screen up after a few minutes of operation. If I let it sit overnight it apparently drifted off and would work again for a few minutes.
Midnightmoon
Ny
I'll give it a whirl. Can you change joysticks from one side to the other to rule out joystick being the problem? Does this happen under a certain situation or all the time? Does anyone think it could be the turret/swivel valve.
Johndogs
Ireland
All the time some times you might get 10 mins out of it other times 30 seconds if it does it once it will do it every 30 sconds
