If you run it long like that you risk destroying the pump completely, it is telling you that the fibre ring that joins the governor ring to the drive is deteriorating and the pieces of the ring are packing the restrictor fitting causing the cavity of the pump to pressurize and shutting it down. The head of the pump will be destroyed, the most costly part in the pump, once they seize they cannot be repaired. There are men on this forum who specialize in just those repairs, they provide free info and I'm putting a plug in for them.
