1845c
Over the winter the splined hub in which the hydraulic pump shaft sits stripped. It was a relatively easy piece to find and replace. I couldn't immediately find a replacement shaft however, and since the shaft spline was actually in decent shape I left it alone and put it in the new hub without taking the pump apart.
Whether that is related to this or not I don't know but my hydraulic pump has recently begun leaking fluid, quite a bit. I have done some searched for repair seal/gasket kits but have so far come up empty. Does anyone know if there are seal kits for it and where I might find one?
Del
Del
