bpp
My Bobcat 334 developed a leak on the boom cylinder between the gland and rod. I've never rebuilt a cylinder before and this is a home owner machine (with a home owner budget). I was hoping someone could tell me where I'm wrong and what else I should consider.
I got the thing apart, cleaned, and now I'm inspecting everything:
- The rod/chrome looks good to my eye, nothing obvious that my fingers can detect for imperfections. Should I still give this a polish? If so, with what (maybe steel wool?)
- The piston has some obvious rough areas. Is it OK to take these down with a file and sandpaper?
- I can see/feel an obvious scratch in the gland where the seal goes. Is it a goner or can that be lightly sanded? I'm not sure if this was the failure or if I did this during removal.
- I heard a bent rod could contribute to leak here. Is it worth having a shop check the rod if I have no reason to suspect it's bent?
- Since the gland is aluminum, what should I put on the threads before reassembling?
