Hitachi 120-2 questions and anwsers
SoutheastSavage
Kasaan Alaska
Travel speed doesn’t change. Fuel gauge and temperature gauge work. No hr meter but that was a issue before. It seems like when pvc was plugged in travel speed would change. But I had to unplug it to get stick in to function properly
SoutheastSavage
Kasaan Alaska
So after running my machine for 10 hrs or so some or most of of the fittings on the conversion are leaking. Will keep you guys posted on what I do to fix it. If any one has any insight feel free to chime in
SoutheastSavage
Kasaan Alaska
Are they just poor quality fittings? You still happy with the conversion?
I think that’s the jist of it. Cheap fitting cheap o rings. I broke one just tightening it. But absolutely I have been out ripping stumps and ripping rock. Machine runs great. And remember before conversion I couldn’t even hardly use machine without it bogging down.
William Ferguson
Richmond kansas
Mine is running better than ever but it's a 790e deere only thing is pilot pump seems to be a little high on pressure and all functions work but if I boom in and bring stick in it bogs engine this is with two shims pvc isn't unplugged but I did pull fuse . should I just unplug?
SoutheastSavage
Kasaan Alaska
Not sure I unplugged mine and it fixed the issue with not being able to stick in and boom up at same time. But mine wasn’t bogging the machine it was just very slow or would almost stop. If the fuse is pulled it should be same as in plugging
SoutheastSavage
Kasaan Alaska
I have still been using my machine. I replaced all the fitting and hoses on the conversion and that fixed my leaking issue so off to work I go. I also equipped 120 with led lights all the way around. A stereo and a new belly pan. Happy digging my friends
SoutheastSavage
Kasaan Alaska
Alright everyone. Machine has been working great operating great
Although the other day my thumb got stuck closed. I replaced thumb sylonoid as well as my handle with a sure grip handle. Now I go to open thumb and it won’t open. Hose at the sylonoid jumps but no pressure to the cylinder. If I go to close thumb it works. So thumb is struck closed. Thinking it may be main relief for thumb part of valve body. Anyone have any insight. I’m screwed right now I have a bunch of brush to haul and I need my thumb to work
JDCrow
Redmond, Or
Just purchased the conversion kit. On the same road as you now. My harness was shot, so new one to clean it up. But ended up with pretty much same symptoms as your machine. I might hit you up for instructions on the kit
JDCrow
Redmond, Or
Get your thumb working?
SoutheastSavage
Kasaan Alaska
Yes I had a mechanic come out we checked the spool in the valve body then we’re gonna check the line to see if anything had gotten in it when the mechanic realized my open side hose was going to my return so when I changed my thumb sylonoid I mixed up 2 hoses. 600 bucks for him to tell me I messed up. Oh well I’m up and ripping again and making money. Yeah let me know if you need a hand you will wish you had done conversion sooner
JDCrow
Redmond, Or
Glad it’s working. Conversion is done. And took your advise and had new hoses made and fitting ready to roll. Blew through 3-4 o-rings on the crazy long fitting that goes into the valve body. Got it replaced and then one goes on the new block. But other than that fine. Still issues with boom up, so it tells me I have to do some cleaning/inspection of shuttle valves /spools
SoutheastSavage
Kasaan Alaska
Did you disconnect your pvc? My machine was really slow when I tried to stick in and boom up at same time. I unplugged pvc and it seemed to fix my issue
JDCrow
Redmond, Or
I did disconnect the PVC. No change. Hammering a trench for my auto mechanic. It’s tedious to push down to go up, but getting it done. Several here have stated i probably have a sticking valve somewhere. So get this ditch done and will start pulling it apart.
Rafik Manzah
Denmark
Anyone that can help with Ex200-3 conversion pictures instructions? I am struggling to get the connection right and get it to work.
What is the concept of the shims? More shims at the top against more shims at the bottom
