Thanks Nige, you're probably right, but if that bolt shears, I'm screwed!
Which would be a worse screwing? Having it break in the shop, with tools, possibly in a heated garage, in a spot where you can work on it, or have it break in the field with no tools, no safe place to work on it, in the middle of a job?
It's like dental work. Putting it off until later will just make it more painful, more expensive, and more aggravating than dealing with it now.
Good luck.
