I don't think you need to remove that sensor to check. You can test while it's still mounted on the main pumps.My excavator is throwing a code for swash plate sensor. I thought I could test it with an ohm meter buy apparently I'm wrong. How does this thing work? Is there an easy way for me to test them?View attachment 235967
I really don't know what kind of sensor this is! There are many types of linear positional sensor.That makes sense to me, but then I would think I could measure ohm readings between A and C, and watch them change as I stroked the sensor. I was unable to do that, but changing out the sensor fixed the machine. I just like to understand what I'm doing and why.
