materthegreater
Hi,
I don't post here often but I'm having a bit of trouble with my mini excavator. It's a Bobcat E60 with a long arm. I bought the machine almost 4 years ago and when I got it, I thought it needed new pin and bushings for the arm to boom joint. So I ordered them from Bobcat and when I got ready to install them I slipped the brand new bushings over the brand new pin and there was a fair amount of slop. I'm no mechanic, but I usually work on my own equipment when I can and it seemed way too loose to me. So I contacted the dealer to make sure I hadn't gotten improperly sized parts, and they sent me tech drawings of the pin and bushings. I measured and they were within tolerance. So I installed them and it seemed a little tighter but didn't take long to get loose again (yes I do use grease ).
I find it hard to believe that Bobcat designs these with that much play. I'm thinking that if I can get a new pin and/or bushings with tighter tolerance that it will stay tight longer. Does that make sense or is it wishful thinking on my part? I've attached the drawing from Bobcat. Seems like 0.28-0.35 mm clearance is a lot for something of this scale.
I would appreciate any input.
Thanks
Thanks
