gokeeper
I was clearing trees a few days ago and stopped to fill the fuel tank, I see hydraulic fluid leaking out underneath. I found a catch pan and basically watched the hydraulic tank empty itself. Since it was dark I left it sit and decided I would look at it the next day. i pulled the belly pan and its dry there, looked all over the engine bay and its dry there too. Decided to get it in a building to work on, had to add a few gallons of hydro fluid to get it in the building, as soon as i added the fluid it started leaking out the bottom of the machine again.
Its leaking near the right rear tire on the Belly, There looks to be a small hole there. I Lifted the cab and removed the belly pan, The belly is dry. Cant see a leak or evidence of fluid. It looks like it would be coming from the area between the motor and cab. Doesn't seam to make a difference if the machine is running or not. Should be easy to find but I haven't found it yet. Checked the chain case its not overflowing.
Unless someone has a better Idea my next step will be to remove the hydraulic tank so i can see in front of the motor. I believe there is the filter return line there but wouldn't think it would leak while the machine is off.
Any Ideas?
Any Ideas?
