Bobcat 763 mysteriously using hydraulic oil
AdamjEdgar
Sydney
Hi guys,
My Bobcat 763 is using hydraulic oil. I found a couple of leaks...1 was a seal and 2 was a cracked hose.
Both are now repaired and no more visible leaks under the cab.
I filled machine with oil and ran bobcat doing some grass slashing with my slasher for about half an hour this morning when all of a sudden I lost hydraulics...it was out of hydraulic oil again.
I checked under cab...no leaks, checked under belly plate of machine, no leaks, checked in engine bay area, no leaks.
The hoses and drive motor on slasher are not leaking either.
I am stumped...where could the hydraulic oil have gone?
Is it possible for the oil to leak from the track drive motors into the drive chain box under the cab?
Knoxville TN
Service Manager
Yep, pull the plug at the front of the machine, that's the oil level for the chain case. If it dumps oil out of that oil level hole then that would be your hydraulic oil leak.
Knoxville TN
Service Manager
Hey, I did quickly clarify myself. :D To check that level plug you have to raise the loader arms to get good access. The practice I developed long ago on those machines, can't preach it enough, is to remove the attachment. It's a quick couple, get that weight off and toss it before you raise the arms and prop it.
lantraxco
Elsewhen
Excellent advice, the newer machines all should have safety prop devices in place yes? Never hurts to remind folks those are NOT designed to hold a loaded bucket or grapple up in the air, lol.
Knoxville TN
Service Manager
Bobcat machines have had incorporated safety props since I know at least the C series machine. And the prop is more than adequate to support the arms and bucket. But me, it's a quick attach, toss the dang bucket, no sense having that hanging over me when it's so easy to toss it. ;)
From what I've heard if the drive motor is leaking, it often has to be replaced. There's usually a problem in the motor that takes the seals out but maybe you'll get lucky. Not sure if your machine has case drain filters but would be good to check.
Knoxville TN
Service Manager
A 763 is an aged machine. Yes, they had case drain filters, would be something worth giving a look at, see if there's debris in there. Filling chain case with oil on a Bobcat is typically a failed drive motor putting excessive internal leakage pressure on the seals in the motor carrier, excessive debris in case drain filter would indicate that. But one could get lucky, being an aged machine, could simply be the seal in the motor carrier has simply gone south. Checking the case drain filter would be a good place to start.
AdamjEdgar
Sydney
Thanks guys,
I thought that was the likely problem...I could see any other place where 30litres of hydraulic oil could "hide".
I assume now the case is overfull, when I remove drive motors, oil will leak out of the chain case sides?
Also, is there an alternative brand for the pair of inline return filters under the cab, i can source other than genuine...bobcat parts are a rip-off!(anyone know the filter specs?)
You might have bigger problems than a couple filters. If you need a need a new wheel motor could be a $2000+ repair.
lantraxco
Elsewhen
Thanks guys,
Just pull the check plug and drain the oil level down to where it should be before you start tearing things apart.
Get the Bobcat part number run it through the Donaldson (my recommendation) or Fleetguard or WIX cross reference web pages, they'll have filters for it.
Knoxville TN
Service Manager
The case drain filters for the drive motors are sintered bronze filters. They're typically washable with solvent unless they're wasted with debris from a failed motor, which then you would replace them along with replacing the motor. Removing the two filters and and disassembling them will indicate which motor is bad if it's filled one with debris
AdamjEdgar
Sydney
Hi guys,
Too much back pressure on rhs inline return filters has caused the rhs drive motor inner shaft seal to blow inwards (see photos).
I am assuming my only option is to go in through access panel umder cab into chain drive area and remove the bolts that hold the drive motor mounting housing to pull this big seal and replace it?
view
view
Ps i tried sharing from Google drive...not sure if it worked from my phone so I attached images as well
lantraxco
Elsewhen
Not seeing the pictures, but yep I think so. Only question is, is the motor bypassing excessively internally so that it will blow out the new seal in short order?
AdamjEdgar
Sydney
Removing linkages etc to gain access to the panel
AdamjEdgar
Sydney
Access panel is now ready to remove
AdamjEdgar
Sydney
This is not going to be easy...that housing also holds bearings for the chain primary drive shaft.
lantraxco
Elsewhen
That looks ugly, have you replaced the motor shaft seal? I'm not 100% sure that inner seal isn't supposed to keep gear oil from coming out?
