After a lot of digging I think I might have the answer. Only thing is seems Prestolite changed the color of one of the wires. They all seem to have a red but the other wire color varies. Yours has red and purple, I have one of those modules with red and tan and I believe I saw one with red and some other color. I can only assume the color of the second wire in some way told someone at Prestolite something about the module.
All that said the easy to understand diagram I found shows red and black so I would think of your purple wire as being black!
See the attached picture:
Red wire being hooked to the + terminal on the coil along with the switched wire from the ignition switch.
