Hitachi ex100-3
mg2361
Pennsylvania
Equipment Mechanic
pvc was of 120-3 machine... changed dp sensor and no change in machine she’s still under load.. would angle sensor cause to much load?
I don't think a 120 will work on a 100, but not sure. Did you contact @LACHAU like I mentioned in the previous post above?
Darreng
Ireland
Was looking at it today again.. with it’s own pvc error code 22 comes up.. it’s got 24v at pump and sending signal to pdsv 1 but no signal to 2... and hydraulics is slow...
With the other pvc (120-3) same code 22 coming up hydraulics is fast in full pump and no 24volts to pump
shopguy
Unplug the solenoids and test the harnesses for 24v on the left wire (I think) with the clip up key on and 0v key off Make sure the solenoid plugs are not crossed the tech book is very confusing about which solenoid is 1 and 2 and what they do.Mg nailed it with how the power gets to the solenoid,if you are getting codes by blink test just remove your jumper with the key on to clear codes same as unplugging DR X
Darreng
Ireland
Aye I ave 24v in the left wire.. what clip? Yeah I checked that there Not crossed solenoid 1 is the outside one right?
shopguy
I don’t have my book here, do you know which one strokes and destrokes the pump for sure?
shopguy
So unplugged key on they both have 24v on the left wire and ground on the right on the destroke and no ground on the stroke ?
Darreng
Ireland
Yes no ground on the stroke plug.. if they are unplugged the 24v will drop off after 8/10 seconds but stays when pluged in.. ever have issues with the earths in the cab
Darreng
Ireland
Where is all earthing points for cab? Yes I think it does but I’ll check it out again in the morning
Darreng
Ireland
Still showing code 22 checked wired to solenoids all seems good and valves are working can’t find any-problem there.. there is one pressure switch faulty behind the cab but from what I understand then don’t have anything todo with controling the pump am I right??
And there’s a sensor of some kind on the dipper supply pipe coming of the valve chest any one know what that is or what it’s for ?
Darreng
Ireland
Hey guys got a lend of a Angel sensor and tryed it on the digger it went well for a while but now back slow again.. any ideas why it done that?
LACHAU
Saigon, Vietnam
First, I would like to talk about how the main pump of the EX100-3 INCREASES or REDUCES FLOW rate.
Note that: PUMP displacement solenoid valve is high speed solenoid valve, they only operate in ON-OFF.
LACHAU
Saigon, Vietnam
STILL SHOWING CODE 22 checked wired to solenoids all seems good and valves are working can’t find any-problem there.. there is one pressure switch faulty behind the cab but from what I understand then don’t have anything todo with controling the pump am I right??
The Angle sensor (A-Sensor) is mechanically linked to the pump valve plate. It converts its physical position to a voltage signal and sends this signal to the controller (PVC).
So that we also have to check the mechanical linkage.
Darreng
Ireland
LACHAU
Saigon, Vietnam
What’s the best way to check the angle linkage?
and if that’s all good could it be a fault in the pvc itself??
  1. It's easy to check whether PVC's working normal or not. You can look at the RED LED on top of PVC.
  2. Take-out A-sensor==> operate any function==> look at the hole on pump. Also take this opportunity to examine the main pump solenoid valve.
Darreng
Ireland
The led on the pvc flashes 1 second on and 1 second off and so on..
I done the lamp test on the solenoids on solenoid no 2 it blinks when u start the digger but nothing after that... no 1 blinks aswell
must check see I the A sensor linkage is ok now...
Darreng
Ireland
Got a new pvc computer for the machine and going good now. only wee problem now is the movements are a bit snappy and seems to load the engine a little? Would it be angle sensor not set correctly?
