Definitely have a good show time crawler if you can get a free ride there and back. If it's working, a great farm crawler. I'm a big fan of big crawlers. More power more weight. If you have a big rock, or a big tree you can convince them to move. But keep in mind the parts are big and heavy to work on. They can also be big $ to fix. bunkclimer saying get both is a really good idea in an expensive kind of way. Trouble is, I'll bet most of these models that have gone to the bone yard. Have been melted down. So a transmission, torque converter, final drive off the other machine would be cheap at $5000. I would think a lot of the soft parts like seals you can get from Cat. Call and see about cylinder seals. Call on a replacement hose. They probably can make them up. The levers probably have booster cylinders see if you can rebuild or replace them. If you can't get those at Cat try Off Road Equipment.
Best of Luck
