coastlogger
I religeously retorque my wheels,budd or otherwise, after a change but what about the inner nuts?Seems to me they could be loose or not real tight, due to a seating issue or ? and I wouldnt know. I figured out that if I loosen off one outer nut at a time, check or tighten inner nut, then retighten outer nut and move on to next one, that would be a way of checking this. Does anyone ever do this and or is it necessary I wonder.. I read up on the subject a bit but found nothing that related to checking inner nut tightness.
