New to skid steers and heavy equipment. But I came here bc I seen alot of info on here and hoping for some help. I have a 2000ishJohn deere 250 skid steer that I'm having some issues with.
Backstory I lost a hose and emptied all the hydro out while operating it. I replaced hose and bleed the system and was able to finish the job, but next day came out and it would lift bucket and tilt fine when cold. As soon as I get operating it quits lifting the bucket and very slow to tilt. It comes down fine after it is raised. So I took the bucket off and tried it without anything on boom and it works fine up down and tilt. I'm trying to get ideas on what could be wrong and what to check. I'm pretty mechanically inclined but this has got me stumped.
I'm going to change fluid and filter and re bleed system coming up on monday to try but any other ideas. P.s. I also am having problems changing a solenoid that is attached to fwd side of control side that controls the boom circuit. I can not get it off as the mount that the pedals are mounted to is welded or seems to be and has a plate above it. It works just the wires are cut some and I can't repair it correctly so I am trying to change it. I'll post picture tomorrow but any help is appreciated
