I'm missing that little one over the swing drive drain. I have the top one that you walk on back to the engine off, I have five hoses to change out the look pretty rotten. That's about $1,500 in John Deere speak.
Take a 20 Liter pail and hook up a vacuum to the big pour spout with tape. take small stiff line like pex and strap to a straight 3/8 or 1/2 round bar to it with pipe sticking out past round bar by 2 inches. Put other end of Pex pipe into small hole on top of 20 liter pail and seal up a bit. Put pipe to bottom of tank to vacuum around and pick up small dirt While the vacuum is sucking. Some guys even put some diesel in the bottom to help with the cleaning if there is a neck sticking up a bit in the tank to stop the diesel from going to pump. Hope it helps. SimonTook good advise and drained hydro tank today.
New sump screen, new hydro filter, new air filters.
Question, worth cleaning the hydraulic tank? And how?
O-Ring work and motor oil change tomorrow. Going to work on figuring out valve adjustments
That walk one on top is at the shop, leaning against a bucket waiting to go back onI Know these are not Small, where did you leave it?
I just watched a John Deere 200DLC that would not hold the arm straight out. It would not raise slowly or would fall down quickly. A new relief valve for that arm circuit was installed and instantly everything was 100%. As the other field tech said. you can take it apart and will find nothing. Not visible to the naked eye, but change for a new one and she is good to go. It reminds me of many a wheel bearing I changed on cars, lots of noize from old bearing, no noize from new bearing. Never seen anything inside. That is my experience. SimonGot the oil all changed finally. Work has been a zoo. Most o-rings on pump replaced and leaks are almost nil. There is a sensor on cab side of pump underneath that hard to get to. I can see it leaking. Sensor is unplugged.
Tore into the valves, replaced o-rings and the nylon washers.
I was hoping this would fix my “boom up” creepy slow. Still no go. I can put the bucket on the ground same and before and it shoots right up.
I’m trying to wrap my head around how the valves work. The body (holding valve) that controls the boom did not have a pool of fluid in it like the others. The springs were fine.
I’m thinking the main spool is stuck? Or at least based on all the other o-rings/nylon rings are shot. Or P1 pressure?
Any suggestions?
