I’m not sure how many years Deere has been running DEF/EGR on their engines to meet emissions BS. Not even sure what year the US started requiring it lol. What I can tell you is based on my experience with trucks and drill rigs running with it.....
Minimize idle time. Warm up and cool down is fine. Hours of needless idling is not. The DPF doesn’t like it and if the engine isn’t under load and making heat stuff doesn’t want to work right.
Pick a brand of DEF and stick with it. The only DEF issues I’ve encountered were due to mixing brands. Could be coincidence but it was like $8,000 in repairs so we use Peak out of the box in everything. Zero from bulk pumps. I think you’d be better off relieving yourself in the DEF tank than bulk based on my experience lol.
Keep the coolant per spec and change it per spec. Test it too. When that stuff gets mixed and matched it seems to want to attack the egr cooler and related parts.
If you like to shut your master switch off at the end of the day you can, but with a DEF machine you have to wait for the tank to purge the lines. It’ll have an indicator light by the master. When it goes off you’re good to go. I even wait longer with all the computers our drills have on them. Factory tech tells us to let them have plenty of time to shut down.
Now that I’ve scared you lol. I’m keeping track of around 8-10 pieces with DEF/EGR. Several Cummins powered, two Cat, two Mack and one Kubota. Knock on wood other that an early Ram Cummins not liking the DEF we’ve had good luck. Our maintenance is top notch.
Like it or not it’s what we’ve got to work with LOL. Most of the time it works to the point that other than filling the DEF you don’t even know it’s there. Might have an occasional sensor issue of some sort. In my experience what causes the expensive repairs are neglect such as excessive idle time, poor maintenance etc. If you buy used I’d sure want to see what the idle time percentage is and any repairs it’s had done.
