361brock
Are the rods that go to the pumps stroking when you move a lever?
Is the machine building air pressure? The gauge should be in the green, the adjustment for the pressure is under the big lift door on top of machine. When you lift the door and step in there it's on the side also there is a small air tank that needs to be opened once and a while to bleed off any water or oil that my have gotten in the air system. There are 2 hydraulic full flow hydraulic filters that just drop in from the top, should be able to pry them up with little effort, they are on top with the cap bolts in circle holding covers on. The air pressure relief valve is also right there sticking up with a plastic screw on cover. If you unscrew the cover and lift up on the pin it will relieve the air pressure in hydraulic tank if there is anything in there, which there should be if it's building air. I have all the books if you need a specific diagram.
