70s model d6c leaking fuel
keith-50
Elgin,TX
My 1970 d6c 10k3438 dozer is leaking fuel from tube on bottom of fuel transfer pump. Looking at service manual it appears to have a scroll type injection pump and transfer pump system. Need info on how to repair leak and can transfer pump be removed without having to remove injection pump?
Thanks
D6c10K
Iowa, USA
Is the leaking hose coming from the forward end of the pump?
Haven't worked on a scroll type pump but if it's like the sleeve pump there is a gear pump on the front end. The hose is a drain to keep the fuel from leaking into the crankcase if the seal fails.
If that's the way it's set up you have to pull the pump.
Bluox
WA state
Remove 2 bolts that hold pump on accessory drive and remove pump and hour meter.
When you get new seals ask Cat to print off rebuild instructions.
Bob
keith-50
Elgin,TX
Do they offer a repair kit, I read in another post by some one, they have a repair kit with seals and bushings, or if I buy from cat do I have to buy seporately, thanks
Not sure of kits but without an actual S/N these a re the best I can do, attached are two pages off SIS but not 100% sure if they are right for your machine.D6C pump01.JPG
  • D6C Pump01.pdf
Bluox
WA state
Call your local Cat parts store and check with them ,
Ask about Yellow mark parts I bet they have a new pump and you will be running 15 minutes after you get your pump.
Good luck
Bob
Going by the 10K03438 S/N here are some better files on this transfer pump:
I tried getting prices on seals and gaskets along with the Yellowmark pump but SIS is not giving me those right now
  • D6C pump001.pdf
  • D6C pump002.pdf
.RC.
Qld, Australia
Good luck
Bob
Or get an Italian made aftermarket one for half the price of yellow mark. :)
