OFF
I replaced a switch. Engine is spinning over using the ground controls, but not starting.
I want to check parts in the distributor.
The rotor button is stuck. Any suggestions of removing it without damaging it?
I expect all the parts inside the distributor need a good cleaning/sanding.
try two flat bladed screw drivers, prying on the base of the rotor, as close as possible to the distributor shaft.
