I had Reuben Frazier come out with his Cat/Fecon mulcher and he brought a Virnig grapple for me to use on my Deere 333E.
Meant to take some pics/video, just didn't have time. My camera caught the Cat here though.
I ended up with about 12 piles to burn. I tried burning one and could get it to burn in one spot well, just couldn't get the whole pile to catch. I'll let them dry a few months. In all I think we probably took out about 300 trees in 2 1/2 days. I spent 1/2 a day spraying stumps, shoots and the main areas afterwards, but plan on spraying again in the spring with Remedy/Diesel (in the 4-5 acres where the trees were pretty heavy) and Grazon (all 100 acres). The bottom 3'-4' of every tree was mulched and taken to about ground level. I didn't have time to spray as we went, as you had to kick a lot of mulch around to even find where the stumps were. I don't think my mowers/equipment will catch any of them, unless the ground shrinks a lot, and hopefully they will start rotting away soon. I would have liked to kill them first, but I've had issues with brittle limbs/thorns breaking off everywhere doing that in the past, and it's not easy spraying all around the trees, getting them all in the clusters without taking a lot of thorns. I can grab them and pile them up after he cut them down without spreading/losing too many thorns, although I still have some clean-up work to do, and will have my share of tire plugging to do. I have had pretty good luck in the past getting rid of shoots with mowing after removing the sources, it's areas with trees still producing seeds that seem to cause me the biggest problems. Time will tell, hopefully this will work well. Most of the trees were in clusters and if need be, I can cut these areas, skip haying them, and chemically kill everything in those areas and get a dozer to root rake if necessary until they stop growing. It would have been much more difficult/expensive/time consuming to get rid of roots, and impossible to really get rid of them all. I do know the place looks so much better with those evil trees gone. If there are trees in hell, I'm sure the Honey Locust are present.
Thanks Reuban!
