jerry D enright
I noticed on the case parts order from they show thermostats for the case 580ck 188 diesel, g11065 177-182 degrees and a57641 180 degrees. It didn't say if it was for a diesel or not so my question is which thermostat does the unit take.
After I removed the thermostat and put it into a pan of hot water my thermostat didn't open til 190 degree. The reason I asked is because the radiator constantly overflows and the new coolant sending unit / temperature gauges are not working.
thanks Jerry
thanks Jerry
