I'm having problems with my ginie 34/22bi, boom lift,suddenly the platform mechanisms and the drive steering don't work, when I press the steering or the platform command button I can here the pump motor working, also I see pressure in the hoses but no movement, I did interchange the solenoid valves but they are fine on other mechanisms, the steering works wen I press the boom up simultaneously.
The platform doesn't move.
I disconnect the hoses from the platform rotator and oil squirt from both hoses even wen I press any other commands...it's like the pressure it's fighting against each other??
Are this solenoids supposed to close the oil flow completely wen not in use??
Please help.
Please help.
