Thanks, I figured the mcv would have most of this configured. I probably need to chase down some proper hydro schematics. I do realize I can just "buy a kit", but I am just a guy that wants to know how everything works. It can be handy in the field at times.
From the talk above, it sounds like the thumbs don't run at full system pressure? Is this more of a fail safe to protect other components, especially the structure of the stick?
As to the control, I am not yet sure where the pilot system is typically tapped, but I might like some input on either the contact switch on a stick, or a direct pilot foot pedal. I guess I could probably find a servo foot pedal so I don't need to run lines in the cab, but not sure what is typical. Honestly been too long since I ran a thumb machine to even recall how it operated.
even though I typically hate foot controls, I might lean that way so I can modulate the thumb movement while running the bucket. Don't know but maybe it works just as good with a stick switch but you only have one speed there.
