FYI. You'll need the transmission oil drained before you can remove the strainer.
It's a good thing I couldn't find it,,,,,FYI. You'll need the transmission oil drained before you can remove the strainer.
Oh come on Dave there’s just so much they can do with a cellphone in their hand and their head up their ash.lolYou can always tell the owner you won't work on it until he pays for a manual or gets copy of what the manual shows for working on the brakes. The shop that rebuilt my engine was kind enough to print out the removal procedure for me. They've done the same for other things I've had to repair too but I've spent a fair amount with them. That said it was with the old service dept. team. The new service dept. is brutal though. Had to pay up front to pull a sprocket off a hyd. motor and they had my motor as collateral. Go to pick it up the next day and it hadn't moved off the counter. Then one of the parts guys is upset at me because I was asking the difference between 2 similar hydraulic filters listed for my machine. They are the distributor for the filters. Shouldn't the distributor be able to find out about the products they sell? I went with the newer filter listed and found online it is a 5 micron and the older listing was an 8 micron. Distributor should have been able to tell me that.
And I for one can never understand the philosophy of people who in some cases pay tens of thousands of $ for a machine then jib about paying $50-100 for a manual.F,O,G and manuals cheapest money an owner can spend
Yes I agree, If having the manual for the machine saves an hour or two of down time it has paid for itself. And if it eliminates just one service call from dealer it is almost as good as winning the lottery!And I for one can never understand the philosophy of people who in some cases pay tens of thousands of $ for a machine then jib about paying $50-100 for a manual.
