Shipping for 500 lb pallet
AllDodge
Kentucky
Looking for a LTL shipping out fit for one pallet 513 lbs, 4ft x 3.5ft x 3ft high
Fresno CA to KY
AllDodge
Kentucky
Thanks, didn't know Fastenal was a LTL shipper
Just used YRC ship calculator and there showing $230 and 6 days. That's doable
Will see if Fastenal will give a quote
AllDodge
Kentucky
Just looked them up and they list only routes are called Blue Lane and neither pickup nor delivery are in one of their zip codes
Ct Farmer
Connecticut
Look at freightcom.com
Had good prices from them in the past. Their website is a little unruly and you need to set up an account but they get rates from a ton of carriers. They were better than going directly to a carrier.
Joel59
NY
Fastenal goes store to store. I've used it in the past to ship pallets of parts across country. I found it to be very reasonable.
Birken Vogt
Charter Member
Grass Valley, Ca
I would jump on that YRC rate, that seems very good. Ordinarily I would use a broker, though. The companies usually mess with you if you go direct.
treemuncher
West TN
eatin' trees, poopin' chips
Last I knew, Fastenal had stopped Blue Lane due to the Covid crap. YRC has good rates, I've used R&L with excellent service and Blue Lane was also good when they were working it. I've also used FreightCenter.com with good results.
lantraxco
Elsewhen
Yep, as far as I know Fastenal is still social distancing so no freight. Basically they have dedicated trucks delivering to their stores on set routes, so any freight they took in went back to the shipping depot in the empty truck, then if needed would be rerouted through connected depots and finally out with deliveries to the nearest store to the receiver. Good idea really.
