NH575E
After getting my battery issues sorted out my machine developed a fuel problem again. I discovered my pre filter had come apart and I had some contamination in my sediment bowl. I replaced both filters and cleaned out the lines and fittings but I was having trouble getting it to start and stay running. I suspected the seals on the fuel lines between the sediment bowl to filter and filter to injection pump.
Searching the available parts lists I could not find a New Holland part number for the line seals. I found the listing for the lines but it didn't show the seals separate so I assume NH wants you to buy the lines.
From what I could tell the seals may have started life as a simple rectangular rubber seal but mine were deformed and had adapted their compressed shape. In addition they were cracking and needed to be replaced.
The ends of the lines have an inverted flare and so does the adapter fitting they screw onto. That means the seals act as a compression seal since the flares don't mate male and female.
In a former life I was an auto tech and I happened to remember the small injector seals I used to replace on early 70s Volvos may be a good substitute. I found a listing for Standard #SK10 that included large and small seals for a 6 cylinder using Bosch D-Jetronic fuel injection. The large seals on these were just locator holders and didn't actually provide sealing. The small seals went on the tips of the injectors and were stuffed down into the holders and retained with a twist cap.
I ordered two packs from Carid at $3.28 a pack plus $10.78 shipping. O'Reily Auto Parts said they could get them but it would be Friday and Carid promised to ship within 24 hours so I went with them.
