Signature Construction
Hi Yall,
I am a new member but have a machine that is giving me some trouble. I have a 2006 Genie 1048 telehandler that is shutting down. I just bought this machine a little over a month ago from a private dealer who sells stuff on the side. Engine is a John Deere 4045. I will start it up first thing in the morning, and it will run for about 8-10 minutes fine, then will shut off like you turned the key off. After that it will only run a minute each time before shutting down. If you leave the key off for about 20 seconds it will start right back up. One thing that I've noticed is that the transmission pressure gauge is pegged, past the numbers, and once that starts to relax is when it will let you start back up. Maybe a coincidence. I had a mechanic tell me that all genie lifts with the trans gauge runs pegged out so im not sure what to think.
We replaced the key switch, fuel pump, fuel filters, blew through the fuel lines, hydraulic filter. I pressure washed the radiator and engine. I replaced the trans oil and filter, and it was pretty murky and low, and I ran it over a half hour fine without shutting down.thought the problem was fixed until later in the day it started shutting down every minute or so. I had a guy read the computer, all it said was code 000970.31, Auxiliary engine shutdown switch active. Looking up the code number reads Non engine fault. Check other Shutdown devices. From his reader everything looked fine, Engine oil was 55psi, water temp was 142. It seems like once the machine warms up is when it starts shutting down.
I am going to replace the trans oil and filer again just to be sure its clean, and am going to replace engine oil and filer.
Anyone had any similar issues? Any help would be much appreciated.
Thanks!
Thanks!
