D6K Codes
ms0115
Ethridge, TN
2014 CAT. D6K2 XL -Dozer
Serial: WMR00661
Can someone tell me the procedure for pulling the codes out of the on board diagnostics? Thanks
ms0115
Ethridge, TN
Codes
E361-2 ECM detects engine cooling issue - Derates
E361-3 Engine gets hot and shuts off
E396-2 High fuel rail pressure - Derates
E398-2 Low fuel rail pressure - Derates
These codes have recently come up. The machine is derating. The radiator is clean. The fan is functioning. Changed the thermostat and temp sensor. We cleared all the codes with or laptop (not E Tech) Could anyone give me help on diagnosing and repairing these issues. Thanks for all your input over the years.
RowdyJ
Aus
Got these codes on a D6 any help appreciated also got the codes mentioned above
Can you start with a Serial Number please. It makes it easier to look up information.
So you have the two in your photos plus which of the other ones mentioned above.?
3547-03 is a problem in the circuit for the water detection switch on the fuel filter bowl.
E283-3 is a low charge pressure event but in order to go any further the machine S/N is required.
  • MID036 CID3547 FMI03.pdf
