filas4life
I have a brush buster with Eaton hydraulic motor and it has a pressure relief valve (block) before the motor. Hit a stump and the mower will now only engage at about half throttle or less, when you go past half throttle it shuts off. I am guessing the relief valve was damaged? These are nearly $1000 to replace on this model. Can they generally be repaired or must be replaced? Any help would be much appreciated? Thanks
