AMBMike
The dozer I run has had a random electrical fault all summer. It'll run perfect for several weeks to a couple months then over several days it will act up every little bit.
The symptoms: the first thing I notice is the GPS system will shut down. When I go into GPS diagnostics the only thing showing as connected is the CB460 control box. Both MS992 receivers, the SNR930 and the Cat ECM all show disconnected.
Next the yellow diamond warning light on the dash will light up. When I check the faint codes the fault codes on the machine dash it is showing 872-09 and 246-09.
Sometimes when this problem is active the machine will suddenly totally shut down momentarily like I've turned the key off and immediately turned it back on. Usually when this happens the problem is "fixed" for a long time. Other times the problem disappears for a while on it's own.
I've checked every harness and connector I can get to and I'm out of ideas.
Any help from the Cat gurus here will be greatly appreciated!
The machine serial number is CAT00D6KAWMR00579
