petepilot
JLG8042 telehandler 06 i believe has no response at all when shifted into second gear all others work `makes no noise. bad relay or bad shift switch?
0160033895. this is an auction buy i have not done a lot of checking yet` but tilt does seem a little slow and the tracking is a little wonky. showing roughly 4700 hrs.You may have a bad proximity switch locking out second gear. What's the serial number of the machine? Ill look at a schematic and see what's there. Don't condemn the shifter yet. Does the frame tilt move very slowly? Regardless of if the boom is under 20 degrees or not?
none either way, and it is skytrakOkay-I verified the S/N. It's an 08 Legacy model. Boom angle switch doesn't appear to lock out the shifter. No forward or reverse in second gear?
been poking around in this thing all afternoon`found 4th gear a little finiky also . swapped out the shift switch with another did not make a difference. i have the panels all off now and am checking all fuses and relays not sure what i`ll find . as for forth gear it will go in and start to move but will drop out if letup on accell.Okay. Skytrak it is. I'll look at some things.
not yet will do more digging today.Do you have a transmission model and serial number?
found another group of wires going into trans. but everything is sealed where the shifter valves &solenoids are located i`m going to let someone who knows what he`s looking at go in there.`more than i want to tackleLet us know how its going and if we can help. Good luck!
this trans. has a barcoded sticker on it 3 separate groups of #s anything i quoted as a serial # would be only be a guessDo you have a transmission model and serial number?
Can you get a few decent pics of it? Maybe someone might recognize it.this trans. has a barcoded sticker on it 3 separate groups of #s anything i quoted as a serial # would be only be a guess
have to get a better camera under there for that phone does`nt cut it may try that tomorrowCan you get a few decent pics of it? Maybe someone might recognize it.
will do. no mfg. name on it that i could seeTake a pic of the transmission shifter also. I’m wondering if it is a ZF or Carraro tranny.
The manual says it's a 4WG98 ZFwill do. no mfg. name on it that i could see
