Hello all
So i have a Kobelco sk 150 lc about a 1998 or better which i just purchased which also came with a thumb. We have been trying to use the thumb and the thumb will only go up into the stow position and not come down to squeeze anything. The pedal appears to be a on /off type pedal and doesn’t have a second pedal so we believe this machine was only setup to be used with a hammer or some sort of one way hydraulic attachment . The pedal has two wire one power and one wire going to a solinoid which then has a hose going to the valve that supplies the thumb. Any help would be appreciated . Any pictures or part numbers that i will need to make this work also appreciated,
respectfully
garrett
respectfully
garrett
