BillHoughH30G
Does anybody have a picture of a OEM diesel electric fuel pump that went with this payloader. And do you know what the PSI was for it.. or what a replacement could be that's available.
Might help to include what engine is in this Hough as they often installed a variety of different engines. I know on some of the bigger models they could be had with IH diesels, GM diesels or Cummins diesels!Does anybody have a picture of a OEM diesel electric fuel pump that went with this payloader. And do you know what the PSI was for it.. or what a replacement could be that's available.
I was going to ask why the injection pump was off. Did you even try to start the engine or did you get the machine with pum already removed? If it was removed to have it fixed then if is at a shop that knows what they are doing they should be able to tell you what you need for a supply pump or if one is even needed. It could be that what ever might have been on there was a failed attempt to get the engine to run.I was going to asking what difference does an electric fuel pump make if you don't have the injection pump. Looks like most if not all the tubes are gone as well.
I would suggest trying to find a manual for this machine. I see one for around $25.00 not sure how good it is but might be worth a chance:It's a cool project. Just going at my own pace. Next up trying to figure out hydraulic filter. How to clean
