jsmith6752james4now
Case 1840 serial # JAF0154782* it looks likle the outer rod moves with the boom and float . thanks
Yes but there are two balls and two springs. Have not had one of exactly that style apart that I recall but thin you have to remove the housing #23 to get access to the two not shown in the drawing.if I can clean the ball and spring out would that help? Is that the detent? 16 19 22
Correct.I need to take off #23 not #6 correct?
Yep! and be ready to catch the balls when you pull it off. Assuming they are there or not rusted in place.I need to take off #23 not #6 correct?
