Cat 289c main pressure relief valve
RPD
Erie PA
I am working on a 289c2 and have low pump pressure. I am not able to find the main relief valve to try and turn it up. Any help how to adjust main relief pressure. I have found Aux., tilt, and lift line reliefs. Just can't find the main relief to adjust. Pressure now is 2750 and I need to be at 3340.
As above - S/N.? Hours on the machine would also be useful info.
Another thing. I wouldn't suggest to go playing with relief valve settings until you've cut open the hydraulic filter and inspected it for debris resulting from wear or damage to the pump. Changes to the relief setting could potentially cause a catastrophic pump failure.
RPD
Erie PA
S/n is RTD00680 hours are 4231. I just need to know where the adjustment for main relief pressure is.
Without the S/N it would be difficult to guarantee the information. Here's the procedure.
I still think you're potentially missing a trick by not doing a hydraulic filter cut before going in with tools twirling to adjust the MRV. I wouldn't be at all surprised if you found it full of brass shavings.
  • T&A Main Relief Valve.pdf
RPD
Erie PA
I had already cut filters. Normal wear metals in it. Nothing excessive. I am not some joe just going in and twirling. I worked for Cat for 15 years and now on my own. I also posted the pics of the main control valve and part number of it.
RPD
Erie PA
RTD00680 is the S/N
Mark250
victoria,Australia
heavy equipment technician
according to the serial number that is XPS highflow machine which is a completely different testing procedure
There is no main relief valve in the control valve
